Anchor Rode Compartment Drain
Capt Ron
C-302 SC
FMLT3124H213
Annie
My 2013 CB31 drains ok, but does not drain out of the Bow drain under the box. It drains into the bottom of the boat. Is this normal? I've tried running a wire from the top and bottom of what appears to be the drain with no results.
Hello,
You should have a clam shell that is on the FWD port side of the bow, if there is one there then most likely the hose hase come disconnected from one of the ends. You can check this from the vberth. All the way FWD in the vberth there is an access panel that will allow you to either inspect or feel for the hose. Let me know if you have questions. Email is the best for me.
Thank you,
Kevin Lamont
