Anchor Washdown
R Baker
On the 29C the Washdown pump is in the engine compartment and the hose connection is aft. Has anyone run a hose internally from the pump to the anchor locker ? Is it possible ? With a simple shutoff forward the Washdown could be used from either location.
I think it would be do able but I would plumb it in with proper plumbing pipe
I have one of those expanding hoses .. It reaches .. I just hook it up and run it to the front when I need it..
Yes, I was thinking of a permanent installation equivalent to the standard of the on board plumbing installations. I'll need to explore a bit in the boat's nether regions. This stuff, the factory could do pretty easily before the deck goes on...hint, hint.
15 degrees here in Ontario today ...getting closer.
It can be done. I had it done on my R-27. I did not do the installation. I had my dealer do it when I purchased the boat. At the bow it runs along the starboard side above the headliner and enters the anchor locker with a valve. There is a hose fitting on the outside of the locker. A very nice and clean installation. The piping was a pecs type flexible tubing.
