CaptnRanger
- Oct 18, 2021
- C-28
- FMLT2723H122
- SWEET RETREAT
What has been found as best way to mark anchor chain and rode for length.
CaptnRanger":2gjgrkyn said:What has been found as best way to mark anchor chain and rode for length.
Capt’nKarl":2uqwtkxp said:In Florida 99% of the time we anchor our R-23 in less than 10 feet of water, more likely 5-8 feet. I have 50 feet of anchor chain and 50 feet of anchor line. I think the deepest I’ve ever anchored in is 15 feet. I painted the chain with neon orange spray paint. Easy Peasy. At 10 feet I painted 3-4 links of the chain, 20 feet 6 -8 links, 30 feet 12 links and at 40 feet 15-20 links. After dozens and dozens of anchorages I’ve never seen the 40 foot mark but that’s here in Florida.
Chimo":2u1l99a5 said:Spray paint mid point on the chain and heat shrink every 25 ft on the rode, alternating red and black.
SgtAlf":2kidylc2 said:Chimo":2kidylc2 said:Spray paint mid point on the chain and heat shrink every 25 ft on the rode, alternating red and black.
How does the heat shrink hold up going through the windlass?
This is genius!it4llc":1qftixod said:I did the same - colored zip ties, and then took a small dowel and put the zip ties on that in the same order with the lengths written out between the zip ties to use as my 'cheat sheet'.
Submariner":1d9z4tvo said:CaptnRanger":1d9z4tvo said:What has been found as best way to mark anchor chain and rode for length.
I used line whipping. Easy, inexpensive. Cheap to re-do if it wears out. Runs through the windlass without issue.
The chain I have is 50', so I just marked it at the 25' mark.
For the rode, I marked it every 30 ft (5 fathoms). Which was 5 marks for 200' of rode.
