Anode for Turster R27OB
Bob&Jilly
Fargher Lake WA
FMLT2757*818
Lynnsanity II
I am trying to get the part number for an anode for my thruster. I will need an aluminum one.
We had a 2020 r27 and the thruster did not have an anode. I think it’s the same for newer r27 too.
R29 and 31 have anodes on the thruster.
There is no anode on the R27-OB for the bow thruster.
All the anodes, external to the Yamaha F300, on the R27-OB are listed here, with part numbers:
Anodes - R27-OB
Anodes - R27-OB
Thanks, I read a suggestion that that the thruster anode needs to be changed, That said. what protects the thruster for electrolysis
The diesel inboards boats have different thrusters than the R27-OB. Those thrusters require anodes. The 110TT Lewmar thruster on our boat doesn't. I would assume the material the prop is made of isn't subject to electrolysis is why there isn't an anode for it.
Thanks, it has not been a problem. I am just updating all anodes for fresh and brackish water
Having read that there were thruster anodes, I ordered a couple and tried to install...
Thank you, great info. Does the same hold true for R25-OB make year 2025? Will the same part numbers you have on https://www.letsgochannelsurfing.com/boat-maintenance/anodes work for R25-OB as well?
The impellers on the ob thrusters are polymer. Won't corrode, but should be painted with AF to keep the critters away.. I think the gearbox is also polymer, but not sure
