Another dumb question.
jimbeam
C-248 C
FMLT2545G708
waite & sea
2020 R27LE cannot find the webasto heater. Says it is under captains seat. Also the filter is on the port side under the sink. Nope. Also says behind the stove. Well
how can you access it and fill it if its behind the stove? Guess they forgot the KISS principle. Keep it simple stupid. 🙂. Maybe it's just me. Naah!
I’m pretty sure the luxury edition does not have the Webasto diesel heater. If you have a heat pump then no diesel heater.
Hi Jimbeam, you should have the Webasto heat pump which is under the helm seat. Unless someone added a Webasto diesel furnace after they took delivery, you will not have the diesel fuel tank which would be behind the stove. There is no need to fill anything for the unit that was installed from the factory on your boat. Feel free to reach out to our customer service manager and share some photos if you're troubleshooting something. kennymarrs@fluidmotionmarine.com
No dumb questions! 🙂
Not sure it’ll be helpful, but Ranger has a video on operating the Webasto heater:
A 2020 LE most likely has a Velair air conditioner.
They switched to a Webasto air conditioner/heat pump on newer models.
The NW editions had a webasto diesel heater.
Mid year 2020 is when the salon change occurred.
The location is under the helm seat. Either pull the seat up if it’s got the raised salon, or pull the microwave out and you’ll see it.
If your stove and sink are right next to each other, you’ll only be able to access it by removing the microwave.
If your stove and sink have counter top space between them, you’ll be able to lift the helm seat strait up for easy access.
