Hydraulicjump
- Feb 10, 2011
- C-30 CB
- FMLT2911F415
- Non-Fluid Motion Model
- Necky Looksha VII, Liquidlogic Remix, Jackson 4Fun
- La Barka (2015)
We all have to be vigilant in paying attention to our engines, but sometimes we don’t know what to look for. I had a good mechanic schooling me the other day, hopefully with a good outcome.
Pacific Power in Seattle sent a great mechanic to do a standard service and coolant change on our Volvo Penta D4-260. While he was working on it he called me to look at something I had seen, but not paid attention to. There was a collection of white salt crystals on the front of the charge air cooler—that large green rectangular box with fins on the port-side rear end of the engine. I think the rest of us call it the intercooler. This connects to the raw water pump and helps cool the engine with seawater.
The crystals were formed at the contact between the main housing and the cover that connects to the raw water pump hose. It was clearly a leak that was precipitating salt. And closer inspection showed that the leak may be starting to drip on the starter motor, which can only end badly.
So check for white salt crystals on all the connections between the raw water pump and the charge air cooler. This may be a sign of trouble. And, as in my case, be sure to check this before your five year warranty is up! This is a very expensive fix that takes three days.
Jeff
Jeff
