Any good bird deterrent ideas?
Bruce Moore
Staff member
USFMLT4104I
SSBN 658 Mariano G. Vallejo
Soundtrack
This guy has decided to hang out on our bimini. Even when he doesn't swoop away screeching when we arrive, it's obvious (yuck!) he's been there and done that. 🙁
Anyone out there found an effective deterrent - spiders, evil eyes, plastic owls, etc. - for Great Blue Herons? (no David, I'm not getting covered moorage)
Our messy guest is seen here on our dock neighbor's boat.
Bruce
We tried one of those plastic owls... the osprey landed next to it. :roll: A friend gave me a plastic snake - I thought, "What could it hurt? I'm not out anything." Haven't had any birds on our deck since then. Prior to the snake, years ago, I made a "Mad Max" (my definition) attachment for the top of the mast on one of our sailboats - I ran long pointy screws through the bottom of a plastic jug and strapped it over the top of the mast, with the screws sticking out. That worked REAL well.
Good luck with the situation,
Jim B.
A 12 gauge is found to work very well. When asked by the "officials", explain that you are nearsighted and thought it was a "Duck".........
If that does not work, I would suggest covered moorage........
Hey!!!!!! Another idea! Strip the insulation from an extenstion cord leaving the copper wire exposed....... Lay them out side by side insuring they don't touch. Plug them in, wait for dinner...........
I hate to be a bit of a kill joy. Please understand that the Great Blue Heron is a Federally protected species of the Migratory Bird Act.
Messing with one, trying to kill one brings VERY stiff fines.
I recommend you contact your local State Fish and Wildlife office (they may refer you to the U.S. Fish and Wildlife Office since they are Federally protected.). There are ways to deter them without hurting them. Again, local authorities can provide help or suggestions.
Best of luck.
Mark
Around the docks, I had always heard of owls, rubber snakes, and things that flash light - like can lids, CD's, fans, etc. I did a google search for "scare birds away" and I found this link for several devices http://www.bird-x.com/visual-repellers-pages-61.php. I kinda like the last one, the sprinkler, though it may not help much if you are in an area where water freezes in the winter time. Other people around the docks say not much helps. Some birds just like a particular spot, and unless you are around to shew them off, they may keep coming back.
Awesome idea David. I know how much you enjoy exotic fowl for dinner. What are you doing for dinner next weekend?
Hi Mark,
I love these birds. Certainly don't wish them any harm. I'm just looking for a way to encourage them to mess somewhere else. There are so many nice rocks, trees, pilings, and other attractive targets.
Benevolently,
Bruce
Had a similar problem and bought a 6 ft "Bird Spider" with the sandbag base and simply placed it in the center of the bimini. Work's great and haven't had a problem since. Other mounts are available. It should do the trick.
http://www.absolutebirdcontrol.com/products/bird-spider
I would caution that asking any "authorities" concerning the problem immediately moves you to the top of the suspect list if the bird turns up dead. Probably the less said about it, the better.
One nasty side effect of having the bird up there is that the top will be stained, perhaps permanently. The sooner you are rid of him, the better. We had a cormorant hitchhike on our bimini overnight in a bad storm while crossing from Pensacola to Clearwater. The greasy stain he left was there for several years. Fish products make up essentially all of their diet (as in herons, ospreys, and pellicans) and the resultant debris is often "rich" in non-soluable oils. The cormorant, of course, also preened with oil so was really a greasy bunch of feathers.
I have seen seagulls sit on top of owls when all the other landing sites were occupied. They will discourage many species, but not all.
The snake did work well on the swim platform of a friend's boat. Whether it would work for this guy is only a guess but they are cheap enough to try. You should use one of the large, inflatable snakes. I suspect herons and/or ospreys might try to eat a small one.
I have seen osprey kites ( http://www.biconet.com/birds/jackite.html ) flown from a VHF antenna discourage all sorts of birds. It might be worth a try.
if you can figure out a way to stretch a few lines across the bimini, about 6 to 8 inches above the fabric, that will discourage many birds since they get in the way of their landing. I have seen that work well to keep pellicans off the rails of several boats.
Bruce:
We've had bird issues over the years, it can be rather frustrating! One thing we found to work well was monofilament fishing line tied in a line to several points in the area you're wanting to chase the pests away from. It's inexpensive, easy to set up and if it doesn't work you can go fishing with what's left over.
Jim
You can hang a pennant like this from the mast, but don't use a Jackite. I have one and they are really neat but pretty delicate just like a kite. When on the beach in a camper we'd attach a bird Jackite to an old rod and reel set in a holder in the sand, get it up a couple hundred feet and let it go for the day. I may try it off the aft end of the boat on the hook. Its not for near point work. Still the concept is sound, consider a nylon pennant with moving parts hanging off it which works at anchor or mooring since it will always stream aft fluttering over the cabin (this one is sold by Overtons.com):
However, even on a mooring this last summer my cabin roof stayed bristol while the bimini was covered with bird poop something fierce. I explored spiders (they come in different sizes (4', 6' and 8') which, as said before, work well with a sandbag mount on top of the bimini. The problem is where to store the thing on the boat underway as it doesn't fold up–you sort of bunch the wires altogether but its not flat and the 6' or 8' model would have to go in the cave. If you are committed to the spider option, shop on the internet. The Daddi Long Legs 6' model ranges from $40 to $49, with the cheapest I found at Absolute Bird Control http://absolutebirdcontrol.com/products/bird-spider as did Tampa Tug per his note above. Plan on another $30 for a base or $48 for a rail mount base.
The best option I found was the old standby 6 foot Gullsweep which costs about $40; it also comes in a 3' model. Its not cheap, but its actually nicely made and pretty durable and worth the money.
While I bought a sandbag (not cheap, around $30) I was afraid the thing would eventually put a sag in my canvas if it moved off a bimini support–the same problem exists for the spider. The bag does have attachments for tie down ropes, but now that's getting to be a hassle... Instead I bought (another $31, but also very well made) a neat rail bracket which attaches to the aft sport rack in the middle. It comes in two versions, one for rails up to 1" and the other for rails up to 1 5/8" which is overkill:
The best thing about the Gullsweep is that it folds to 3 foot long and nicely packs away on the ceiling bulkhead of an R25. When you stand at the helm and look aft and up, you'll see the ceiling is stepped with teak boards spanning the width of the cabin at two places. Its tough to describe this, and I don't have access to my boat to take a picture at the moment, so I'll borrow a TugNut's picture from his photo album to show you this excellent storage place I think few people even think of. By the way, can you guess which TugNut would have a shark gun aboard a 25' boat? The answer is below:
Instead of a shark gun, I mounted a spare (collapsed) boat hook in this nifty spot using those SS clips we all buy at West Marine to mount a boat hook in our cockpits. When not in use the folded Gullsweep fits nicely behind it. The boat hook is a Shurhold model with this attachment on it so I can grab it, attach a line and "try" to lean out the helm window to loop cleats. Thus, its appropriate to carry it inside the boat. So far I have not yet caught a cleat, but did manage to loose the attachment trying. The Shurhold pole does double duty as a brush handle and you can even mount a paddle to it (sort of a poor man's kicker engine):
I leave the mount in place on the rail. The only downside is that the sweep only covers the front half of the bimini. I'll have to wait until next summer when the boat hangs on a mooring all season to see if it sweeps enough to deter the flying rats, as we call gulls on Cape Cod. BTW, did you guess captd (Darrell) of Mis Dee and then Lucky Fin would carry a shark gun!
