Boat R27 has AGM batteries but wish to switch to Lithium. Anything special should be done to the electronics to switch?
jimbeam
www.letsgochannelsurfing.com
jimbeam
Battery
Class t fuse
Confirm if your converter will charge lithium
Confirm if your solar controller will charge lithium
Add a multi bank charger for your thruster and starter battery
Dc to dc charger replacing the ACR
That's honestly all you NEED to do
true true on the audible alarm. i take it for granted with the cerbos we install on thatABYC also requires a battery monitor with a physical gauge be installed so there's an audible alarm that can be sounded. The physical gauge can offer Bluetooth for convenience, but there's no way to get an audible alarm from a bluetooth only battery monitor.
It's also important to verify the battery charger will charge the LFP battery that is being installed.
I had a Skyla 70amp Victron battery charger that supported LFP, however, it wouldn't work for my LFP battery. The Skylla required a communication connection to an external BMS (Victron's) to tell it when to stop charging. The Lithionics battery I installed had an internal BMS and thus, couldn't communicate to the Skyla.
The ABSO 20amp multi-bank battery charger that came with my R27-OB also supported LFP. However, the tail current settings were 1, 2, and 4amps. The 320 ah Lithionics battery I installed required that charging stop when the tail current dropped to 10amps. I had to install an ABSO 60 amp battery charger as it had tail current settings of 3, 6 and 12 amps (so I set it to 12 amps, so as to not overcharge my LFP battery). I kept the 20amp charger for the engine/thruster and added the 60 amp charger for the house bank.
I looked at converting an RT29 inboard as well. The inverter/charger that came with the NW edition stated that it supported LFP. But there wasn't any configuration in the inverter/charger to actually support LFP. It needed to be replaced to function with LFP.
As DDean implied, it’s also very expensive to convert. I remember costs of $8,000 to $12,000 to do the conversion.
Much cheaper to go to 400+ watts of solar, a portable power bank and or adding one or more AGMs to the house bank.
Have converted a M.H. from lead acid to lithium. Not too bad there but really different on the tugs. There is another Youtube video that describes the process to convert Just the cabin to lithium. I have a Ecoflow in my M.H.. It makes my coffee, powers my 3.2 cu ft freezer for 24 hours. I then run my onboard generator(2K) for one hour a day to fully recharge the ecoflow(1260W) and do that on a daily basis while boondocking. I have a R27 with lead acid batteries and am deciding to 1. buy a ecoflow, or 2. buy a small 1000 w gas generator to carry. Lots of pro's and con's on this subject. I like the idea of carrying the generator for fail safe measures.You’ll want to speak with @Submariner as he did it. You have a rewire the boat. I’d consider carrying lithium battery packs like Ecoflow or Bluetti that just plug into shore power and run the boat off of those or recharge your AGMs from those instead. It’s very difficult to convert. It’s goes way beyond simply changing the batteries.
