Levitation":2pmq8lzl said:IF I were adding an autopilot I would make it Garmin so that it seamlessly connects with the MFD and gives you automatic track steering.
Jackcash":1fw12hhy said:It is a new installation and the existing systems are Raymarine so I wanted to stay with that. A Raymarine tech. rep told me after my first post that the EV 100 would be as good as the EV 200 and should work just fine. I could use some advice on that installation.
baz":aztpyjlc said:What method did you use to 'bleed' the hydraulic lines ? I ask, as I had Garmin purge air from my lines shortly after purchasing my R-25 (Classic) in 2009 and they used a fancy pump device that looked expensive to me. During the following 6 years I never had any issues with air in the lines.
