Autopilot CCU location
henningbuus
C-302 SC
FMLT2926B010
I recently installed a 200W solar panel on my R29 2010, and routing the wires through the stack and down to the house batteries. In the process I must have done something to the autopilot wiring because it does not work. I suspect the CCU is either damaged or lost power, but I don’t know where it is located?? Can anybody tell me?
Henning
On our 2012 R29 the CCU is behind the galley cabinets, accessed through the lower left hand door. The NEMA 2000 backbone, which had come loose on ours, was accessed by removing the refrigerator and climbing in the hole.
Thanks Brad Owens, I found the CCU as you described under the refrigerator. I disconnected and reconnected the data buses, and that solved my problem.
