Aadudley
- Dec 30, 2016
- C-26
- FMLR2506F516
- True Blue
We own a 2016 R25SC and are planning to move the boat to warmer a warmer climate. I've read several articles about fiberglass osmotic blisters on boat hulls may be more prevalent due to warmer and longer boating climates. With that in mind we are contemplating a barrier coating prior to bottom paint. At the same time I have read the following:
"As builders determined that blisters resulted from water penetrating the gel coat surface, the barrier coat (usually an epoxy, or similar material that seals out the moisture better than polyester gel coat) was born. Water barrier techniques and products have grown into maturity over the past few decades"
Not knowing the manufacturing process of Ranger hulls, I have two questions. 1. Does Ranger use an epoxy as discussed in the previous paragraph and if so what do you recommend for a bottom paint. 2.If Ranger does not have an epoxy do you recommend one or better yet what do you recommend for hull protection. Our boat will be spending time in Florida after the hurricane season and soon will be in Tennessee fresh water lakes for fall and early winter.
Thanks for the help
Thanks for the help
