Bathroom/Galley light
Ainokea
C-248 C
Boston Whaler 170 Montauck
Ainokea
I have a 2008 R25. Recently both the galley light sconce over the stove and the overhead light in the head went out. Tried replacement bulb in both lights. Still did not work. Further trouble shooting show that there is no power to either lamp. I know these were wired to the hot battery bus but I cannot find a fuse for these lamps. All the other equipment works. Has any one else had this issue? Any thoughts? Really don't want to start tearing the interior out to start chasing wires!
Thanks in advance!
Frank
"Ainokea"
If you don't get an quick answer give Kenny, Andrew or Ivan a call at the factory in Kent, they'll certainly give you a hand.
Jim F
On our 2008 Laurie Ann, those lights were controlled by the same breaker on the 12 volt panel. Are those breakers on?
Jim and John thank's for the replies. The items that are 12v all seem to work. Both cigarette plugs,wash down etc. I seem to be missing a fuse somewhere. Will be back at boat later in week for more trouble shooting.
Frank
Frank, Just took a look at the wiring diagram for our MY 09 classic ('08 build) and it appears the lights you are having an issue with are interconnected through a 15A fuse. Mine, I think, is located on the fuse panel in the helm electrical compartment which is mounted on the access door in the berth.
Mike
Thanks Mike. I will look again at that fuse. It looked good but I will swap it out this time.
Frank
