Stevan47
- Nov 25, 2013
- C-24 C
- Non-Fluid Motion Model
- Recently sold R21-EC
Guys/Gals: Advice and suggestions, please. Currently, I have two 12V (BCI Group 24) starting batteries in my vessel( 600 CCA, RC 130, Rated Capacity@C20, 80AH). These batteries, sealed and maintenance -free, were manufactured in Feb '12 and have given no trouble in all this time. The engine starts first time every time, after just a few turns. Considering they are now just over five years old I consider it great they have lasted this long. Naturally, they are always under cover within the engine compartment and generally always on charge on the trailer when not at sea, so they 'live' in a protected environment and that probably assists with the life span. The onboard charger is a Pro Mariner, Pro Nautic 12-20P, a marvelous device, I might add. For information, both batteries are connected in parallel( I think I've got that correct). The engine is a Yanmar 3YM30.
Recently, after my last period underway, and after leaving the charger off for a few days, , I tested the batteries and found one to be a little under charge, compared to the other. Basically, one was reading 12.87 volts, while the other was down around 12.00 volts, or thereabouts. This is unusual, as generally they have always corresponded, + or - 0.1volts. From this I suspected that one battery is 'on it's way out'.
Anyway, to cut a long story short, noting that five years has elapsed, and not wanting to risk battery failure/total power loss while underway, I thought I should just change out the batteries now.
We have a good choice of battery brands here, so with cost and efficiency in mind I did some research. I have decided on a different brand of battery, same BCI Group (24), same CCA (600), but with slightly lower RC (125) and Capacity (73AH). Also, the physical dimensions are about 1mm less all round, which makes it a better fit in the tray at the back of the engine.
My question is: noting the CCA (600) of each battery is the same, will I still get the same starting/cranking effect from the new batteries, although the other specs (RC and AH) are slightly lower? I understand that while linked in parallel (as mine are) the combined voltage remains the same (12), however the CCA and RC are doubled, as opposed to being linked in series ( I think I am correct here, but please correct me if necessary).
My main reason for choosing the new brand batteries is the lower price and slightly smaller dimensions. Otherwise, they are similar quality and with a two year warranty period.
I would appreciate all suggestions and advice and I trust this post is not too convoluted.
Kind regards, Stevan
