Trisailor
- Jul 8, 2017
- C-28
- FMLT2720H011
- Fancy Nancy (2011 R27)
Many thanks to all on the forum for all the information here about the electrical systems on our boats.
At long last the installation of a new battery charger and inverter is done. As posted here last fall the Promariner combi 1500QS on my R27 failed. The transfer switch functionality quit working – no output, ac input was good, just no pass through for battery charger or inverter function.
Since then, a separate Kisae 3 bank charger and Kisae 2000w PS inverter have been installed. Yesterday was the final QA and light off of the new system. The original AC wire run from the AC panel to the Charger inverter was rerouted to the new charger mounted under the “desk” in the cave. Discovered along the way:
1. The Combi had been worked on before – an additional external fan was glued to the case of the combi - parasitic draw running all the time the battery was on to the inverter, maybe internal fan failed?
2. Prior to my ownership the inverter had been disconnected from the rotary switch at the helm and connected directly to the secondary bus. This caused some weird indications on the AC panel when the new inverter was first turned on and caused a bit of head scratching why the indicator light on the rotary sw wasn’t lighting up. I reconnected to the switch.
3. The new inverter, both smaller and lighter, located in the aft port cockpit locker is better protected from overflow from the hatch scuppers and frees up a little more space for some storage.
4. Still to install, auto switch to disable ACR’s when shore power plugged in.
