rpmerrill
- Feb 5, 2016
- C-28
- BAY RANGER
I seem to remember seeing something on this a while ago. If it is a total re-run please let me know.
Ok, the boat (2012 R-27) is out on the hard waiting for spring under the shrink wrap.
During the winter lay-up the only battery charging it gets is from the attenuated solar charger which has worked great for the past five winters.
I have three chargers on the boat:
1.) The engine alternator,
2.) the shore power charger and
3.) the solar panel.
I am wondering where that charge is usually directed? Do they all go to the same place? It’s not shown on the wiring diagram I’m pretty sure the engine battery is charged by the alternator. From the engine battery there are two ACR’s feeding over to the Thruster battery and to the bank of 2 House batteries. Of course, the ACR’s are two way devices so they can feed back to the engine battery as well.
I am sitting here wondering where the solar charge is going: engine, house or thruster?
Some background to my question
Shortly after the boat was hauled out, I noticed that the engine battery was flat at about 6 volts. Not surprised… it and the thruster battery are over 5 years old. (I replaced the 2 house batteries last spring.)
Luckily, I am still close to shore power connection. I plugged in and charged the batteries for a bit over 24 hours. When I returned they were all at a pretty good voltage. I unplugged and let them sit for a day. The engine battery dropped to 10 volts, then next day to 8 volts then next day to 6 volts. Suspecting a possible unknown amp draw (I was unable to measure one) so then I charged up again and disconnected the NEG cable. Same result a couple days later.
One thing… when messing with the battery cables I noticed that the top of the battery was hot when charging AND when discharging over the next couple days. I took notes, but they are on the boat right now. I think charging was at about 100 degrees. and discharging was about 50-60 degrees in a 40 degree ambient. My only conclusion is that there is an internal fault that is killing the charge. Time for some new batteries. I’m thinking that the engine battery might have been on it’s last legs all this summer. We had no long trips or extended times off the shore power.
OK, with the engine battery NEG disconnected, it is out of the loop. And this is the reason for my questions.
1.) Where is the solar charge supposed to go?
2.) Will my remaining batteries receive any solar charge during the next couple months?
3.) Does the solar charger output go directly to the battery compartment or does it go to the hot side of one of the battery switches? (All the wires are bundled together and it is hard to tell without tearing into the bundles.)
4.) Does anyone recommend methods, such as jumper cables, to redirect the, <1 amp, charging current to the remaining (house) batteries.
