DBBRanger
- Mar 31, 2013
- R-25 Classic
- Still Crazy
I keep my R25 on a trailer and tow it to a cruising spot. The trip may be long (like 5nights/6days to the Keys) and therefore I really wish the truck would keep my batteries charged so that I can use the refrigerator and other power sources especially when 'camping' in the boat along the way. I've come up with a plan that I would love for all to critique.
I expect to make a pigtail that stores in the chain locker that is connected to the windlass positive and negative terminals. When power from the truck is available, I will turn on the rotary switch for the thruster/windlass. Thus the power will track 'backwards' from the windlass, through the switch and to the thruster/windlass buss bar. Here it will charge the thruster/windlass battery until the automatic relays kick in and combine the thruster/battery bank to the house bank and the starting battery bank (that's the way mine is wired - others may be different). This way, I don't have to run separate wires from the battery to the bow. The downside I see is that I have to have the rotary switch for the thruster/windlass turned on and therefore there is power to the windlass. I have read of numerous(?) reports of runaway windlasses so that would be a problem if it occured traveling down the road. To ensure that doesn't happen, I'll remove the chain from the gypsy in case the windlass does start up. Of course I have a line holding the anchor!
My Ranger is not available to me at the monment but I assume I can get to the terminals on the windlass from the chain locker.
I have wired the truck with a 10ga wire from the front to a connector at the back where a separate line will plug into and then plug into the pigtail on the boat. The 10ga wire goes to a solenoid that is controlled by a switch in the cab of the truck (I like to control when it is charging otherwise when it is plugged in, the truck battery will be immediately charging the boat battery even if the truck is not going). I've got a 30amp circuit breaker connecting the solenoid to the battery and a fuse on the line going to the switch in the cab.
Does anyone see a problem with this design?
Doug
Doug
