dougs527
- Dec 30, 2009
- C-248 C
- FMLT2540F70
- Spirit of Unity
When I store my R25 boat, I always turn off the main battery switches, but I still have battery drain. The main battery switches do not cut off power to ALL onboard circuits. For the last couple of years, when I store my boat for more than a couple of weeks, I disconnect the ground battery cables. Disconnecting the ground cable to battery 1, effectively disconnects all battery grounds. By doing this, I experience NO battery drain.
Rather than having to get a wrench out and unbolting the battery ground cable, I’m thinking about adding a ground cable battery switch. I can then turn off this one switch and be assured that ALL power is turned off to the entire boat.
My other alternative is to trace down the leaking power that the main battery switches do not turn off. Looking at the buss bars, there are a number of these circuits like the bilge pumps, wallas stove, stereo memory, and volt meter that remain active.
How have other owners dealt with this battery leakage problem?
