j&lgray
- Nov 28, 2008
- C-28
- Trilogy
Hey Tugnuts!
I experienced a reminder that is worthy of sharing on maintaining those batteries. Most of our boats have the flooded batteries, that is, they have distilled water under those caps. Well, just because the Excide Battery says that is maintenance free on the case, do not take that to the bank. Last summer, in preparation for out 90 day, 1,600 mile river trip in the Tennessee River Valley, I popped all those cell covers and discovered that you have to add water to those cells. Between the heat of the season and the battery charging process, water is evaporated out of those cells.
I also bought a $7 hydrometer from the auto parts store and checked each cell. I found a marginal cell on one of the house batteries. A cell that was about to fail and that would disable the entire battery. The local auto parts store sold Excide Batteries and gave me a credit on a new one.
Anyway, last weekend, my starting battery was quite weak. So weak, that it would not turn over the engine to start it. Using the battery combiner switch, we got the engine started and all was good. Back on the trailer, I found that both the engine battery and the thruster battery were low on water (been only 4 months since the last fill). So after putting a lot of water in those cells and giving the batteries a good charge, I took them out of the boat and had them tested at a battery shop. The good news: all is fine.
I have decided not to leave my battery charger on 24/7 when there is no draw on the batteries. Even though the smart charger has a maintenance setting that only trickle charges the batteries, I think that some over-charging is occurring and evaporating water out of the cells.
So, check those batteries. Get a funnel and a gallon of distilled water and keep the water above the lead plates. Get a hydrometer and periodically check each cell using the directions that come with the device. While you are at it, clean those terminal connections and if you find a black fuse holder, find out that that wire does and label it with a silver colored sharpie pen.
The Blue Sea volt meter will give you a snapshot on the health of those batteries: 13.4 volts is a fully charged battery; 12.2 volts is a battery that is about 50% discharged and 11 volts is roughly a completely discharged battery.
