Ainokea
- Nov 23, 2008
- C-248 C
- Non-Fluid Motion Model
- Boston Whaler 170 Montauck
- Ainokea
Am on a trip on the ICW and noticed the thruster/ windlass battery was weak after 6 hours of engine run time. Got to stop for night and plugged into shore power and turned on batt charger and went to bed. Next morning all batts nicely charged and also indicated by green light on charger. Cool, cast lines and head on out for another 6:30 hours with two quick stops for dog, used thrusters on all stops. Again stop for eve and thruster batt low. Next morning disconnect shore power and test voltage at batts with engine running. Eng start batt 14.1/thruster batt 13.0/ house batts 14.3 .... shut off eng and reconnect to shore power and turn on batt charger and check voltage all 4 batts showed 14 to 14.2 volts. All batt cable connections are tight and batt water level good. Is there a solenoid possibly gone bad and where is it or is there a fuse that might be bad? Scratching my head and cruising on. Any trouble shooting advice would b appreciated. Thanks
Frank
Frank
