Battery over charging on solar
captstu
C-248 C
Shearwater IV (SOLD)
Hi,
When I "sit" in bright sunlight with my fridge running, the battery voltage slowly climbs to 15.3 volts - with solar as the only source. This voltage is checked on the supplied DC voltmeter, an internal added DVM and a portable DVM I trust. Turning on some load, the Radar, for example, drops the voltage to 13.7, a number that feels right for full batteries in bright sun.
I have the "standard" 135 W solar panel and controller.
It appears the controller limiter is not set right, but the instructions for the limiter/controller show no way to adjust the maximum voltage output.
I think this is not a new problem - the batteries were all dry and failed within a week of purchase.
She is a 2010 R-25.
I don't mind replacing the controller, but am curious if anyone else saw this problem. Thanks /Stu
Good morning Catnip,
I would recommend that you put the existing controller in the dumpster & install a Blue Sky, solar boost 2000E.
We had one on our previous trawler with 450 wts of solar panels & have recently changed out the factory Morning star controller for a Blue Sky, solar boost 2000E on our 2012 26 ft Cutwater.
Look up specs on line & shop around on line for best prices.
Good luck,
Mike
M/V Elan
Hello Stu,
I would think something is really wrong if solar charging voltages reach 15+ VDC.
From what I've read, the MPPT type solar charge regulators offer superior charging results in comparison to the PWM controller so that would be the type I would get.
Here (http://www.pbase.com/mainecruising/sola ... er_testing) is a good description of the differences between the two types of controllers. This review tested the results of the two types of controllers when used to charge a LiFePO4 battery bank (which most of us don't have); the end results are going to apply across to Flooded cell or gel batteries as well.
Backing the truck up a little...here (http://www.pbase.com/mainecruising/do_i ... controller) is a good explanation of WHY you need a charge controller in the first place.
Fair winds and solar charging,
dave
You might call Morningstar and ask them. They are pretty responsive and there is a fairly good warranty on the controller.
Hello Stu,
I don't believe we had the solar panel as a factory option when your boat was built.
Was this an add on perhaps the dealer installed? Is the display a Morningstar?
-Kenny
Replaced the Morningstar with an Mppt controller. No more problems
Thank you.
