Hydraulicjump
- Feb 10, 2011
- C-30 CB
- FMLT2911F415
- Non-Fluid Motion Model
- Necky Looksha VII, Liquidlogic Remix, Jackson 4Fun
- La Barka (2015)
For some reason I occasionally get voltage spikes above 15v. This can occur when I first hook up shore power or, like today, when the sun was coming and going on the solar panel. I know the spike has occurred because my Balmar Smartgauge blinks an error code telling me that the voltage was too high. But it is always short-lived and things drop down.
But this often is accompanied by a loud "beep" somewhere in the boat. And of course, when you go to trace the beep, the voltage is back to normal, so I can't find the beeping (bleeping?) culprit.
Here is today's dumb question: is the "beep" the CO detector? I think it is coming from that general direction. And the second dumb question, is it really a problem if there is a voltage spike above 15v, but it settles back down? Today's beep occurred after shut-down in the slip, before hooking up to shorepower. Apparently the solar panel can cause spikes as well.
Thanks electrical wizards.
Jeff
Jeff
