Best way to tie up a 2008 R25
bryant
looking to buy a Ranger Tug R25
Finally putting my new (to me) 2008 R25 in the water. I want to tie up in my slip stern first but am not sure what is the best way to secure the boat. All of my past boats have had cleats on the stern but the 2008 R25 does not. It does have cleats just aft of the steps on the port and starboard side but if I tie up to these I cannot cross my lines coming from these cleats to the dock.
Thanks for any suggestions
Bryant
Welcome, fellow Eastern Shoreman. I'm out of state now but will be returning to the Kent Island area in a few years.
I pursued that same question some time back, but for newer models. I'm not familiar with the particulars of yours. I have to believe the issues are similar. My conclusion: the cleat arrangement is optimized for Pacific Northwest (PNW) marinas that are almost always floating docks, and side tie strategies with fenders pulled tight against full length finger piers.
That's great if that matches your conditions, but as you know floating docks are more the exception than the rule on the Bay. As best I can figure it, you just have to loop over cockpit rear sides, and snake it under the short rails above the cockpit rear, and through the swim platform rails. Exactly what path you take depends on the exact angles you are working with at your dock. Its far from optimal, but seems do-able. I say "seems" because I have not yet pulled the trigger on a boat and can't say for certain. It appears that often the seatbacks in the side cockpit seats are at risk of damage by the lines, but those can be popped on and off and stored in the cabin when not under way.
Once you solve this on yours, I'd be interested to hear about it.
And once you solve that, now try to solve it with a dingy hanging off the swim platform that creates no acceptable options for tie-up. In fairness to Ranger, to be clear, until you get up to boat sizes of approximately 40 ft and up with big cabin roof areas with crane davits, all boats have this dingy problem with solutions that range from bad to less bad.
If you're not on a floating dock I don't se a feasible way to stern tie with factory hardware. I'd add a couple of stern cleats. Or at least eyes on both sides that would let you use the existing cleats without resembling a spider web.
Thought about adding popup cleats to the swim platform but found drilling into the swim platform to mount the cleats was a nightmare. You all have give me several ideas to try.
Bryant
Bryant: I looked into that. It simply isn't strong enough to take the snap loads that can happen. Most have small cleats already there, and they are fine for a quick tie of a dingy or even throw a quick line on them in the midst of docking, but not for more serious long term dock line use. You could yank off the whole platform.
Thanks for that info FWTMD. Guess I will go back to using the aft cleat and try to find a way of running the aft lines around and under the rails. Not really a great solution as I could do serious damage to the rails.
Bryant
