bi fold on R29
Irish Mist
C-288 C
FMLT2922K011
This may have been posted before but thought I would share. When you are doing your weekly or monthly checks Check the screws for the hinges on your glass bi fold into the basement. They tend to loosen over time. I was in some rough water and the top hinge came off the door, The screws had come loose and stripped the caps so I had to order replacements.When I checked the others they were all needing to be tightened... If you check and tighten this will never be an issue. . I am sure was just a fluke it happened but I will check them going forward.
Good idea. Same goes for the set screws on the luggage rack and bimini hardware.
Cheers,
Bruce
You cannot beat Loctite! Use the removable formula and you will be happy with the results. The barrel nuts on my transom hatch vibrated out. They won't be doing that again.
Pat, Ladybug, Too
