Hi all,
Just bought a new (to me) 2012 C-26 and I'm in the process of figuring out all of the systems. I have a few questions regarding the various pumps onboard as I am getting the feeling the previous owner made some changes.
Bilge - I have a forward and aft bilge pump, both operated by the rocker switches on the dash. My surveyor told me each pump also has an electric eye instead of a float switch for the automatic operation that should operate regardless of batteries being on or off. I recently had a fresh water leak and the bilge filled with a ton of water and the pumps did not activate. Does anyone know where I can look for these electric eyes and if I can locate them, short of filling the bilge, is there an easy way to test their operation?
Shower sump - I've noticed the clear box housing the shower sump has water in it, but probably not enough to trip the float switch yet. Is there a way to manually activate the sump without taking the housing out and lifting the float switch? Is there a rocker switch on the dash somewhere that needs to be on to get power to the pump?
Thanks for your help!
