I'm a new owner of a 2014 Ranger 21 EC. The other day while doing some cleaning I noticed that the auto switch never turned on the bilge pump even as the level of the water in the bilge got to the point of sounding the bilge alarm. When I looked into the bilge pump area I noticed two black boxes - switches I believe, which are wired to the bilge pump. Only the alarm switch, mounted higher in the bilge was firmly attached. The other box which I believe is the switch to activate the pump automatically was floating around loose in the compartment. I'm assuming this should not be the case? If it is supposed to be attached somewhere, that spot didn't jump out at me. The bilge pump operates fine with the switch at the helm. Making the assumption here that the automatic switch should activate regardless of the main electrical switch being turned off at the helm? Thank for any help to this newbie tug owner
