synergy
- Apr 4, 2011
- C-248 C
- Non-Fluid Motion Model
- Arima Sea Ranger
- synergy
We love our 2008 R 25 and although it is a challenge to add wiring or plumbing because of lack of access I have always managed to get it done. But something I was aware of some time ago became necessary for me to correct today as I was moving the boat on her trailer enough rain water in the bilge started the pump. After evacuating all the water it could reach it failed to shut down. I don't know if my boat was miss wired or all the early 25s are the same, but the switch in the DC panel only overrides the float switch.There should be a double throw auto/manual/off switch.the only way to stop a runaway pump is to ether remove the inline fuse at the battery or cut the wire at the pump.Fortunately last time I ran wiring from the transom to the DC panel I included a pull string ,so I will now will in the extra wire and replace the switch .
