Bilge pump fuse on Ranger 23
bcarver46
C-242 C
FMLT2352L718
Joy
My stern bilge pump isn't working. It was suggested that I change the fuse, but don't know where to find the fuse for bilge 3 and wonder what amp I should use? Thanks for your help!
Hi bcarver46
Not sure if you already got this taken care of. Rear bilge pumps are on the 24/7 fuse block and are 5amp. Ours is located behind the fire ext. below and left of the main panel. The trim piece that the fire ext is mounted to is removable and fuse block is behind it. Hope that helps.
take care, mark
Hello,
The bilge pump located in the pod (#3) is fused on top of the house batteries. You should find a black inline fuse holder directly on top of the batteries. Give me a call or email with any further questions.
Thank you,
-Tim
Hi Tim
Did you change the system from mine or I'm I missing something? Maybe because I have the diesel?
thx.mark
Hi Mark, your boat is a little different due to the fact that it's the stern drive compared to the outboard. On an outboard model the engine is attached to a separate pod on the transom, where we install a third bilge pump.
Thank you,
-Tim
Hi Tim
Is the fuse for the pod bilge pump still black and on top o the house batteries in a 2019 R-32?
Also when I hauled the boat last week. there was a long piece of caulking hanging from the bottom of the joint between the hull and the pod.
When we puled the plug on the pod, lots of water came out. Is water able to get in the pod from the space between the hull and pod?
Jeff
