The float switch started to act up: failing to shut the pump off once the water was pumped out. Don't make the same mistake I did expecting a solution by ordering the exact same make/model for replacement: The Rule-Mate 500 still specifies 500 gph but the physical size has become larger and the unit will no longer fit in the space allowed. (I note also that the plastic case had failed on the other side of the pump - just under the hose clamp attaching the discharge hose and not visible until the hose was removed.)
The only pump I could find thin enough to fit in this space was a Whale Supersub 650 gph pump, made in Northern Ireland.
