Bevan Hill
- Apr 10, 2011
- C-24 C SE
- FMLT2117I809
- Queen Bess
I need advice to solve a bilge pump problem. Some sort of fault caused the bilge pump on my 2009 R21 to fail. This was preceeded by a developing fault where it would automatically pump out then refuse to turn off. If I then toggled the manual switch on the panel, the pump would stop. However I then saw a remaining low glow in the switch indicator light. In retrospect I sensed this might be an indication that the pump was beginning to burn out or sieze, although the reason for the development of the fault is not obvious.
I purchased both an identical new Ultima sensor and a new identical Johnson pump. I installed both, being careful to replicate the correct linking of different coloured leads. I tested the pump by switching the manual switch on the panel and the pump works fine. However when I pressed the two rings to test the sensor the pump does not begin pumping but rather begins 'ticking' like a clock at about 3-4 ticks per second. Similarly when I poured water into the bilge, at the point when I would expect the pump to activate, again I hear this ticking sound but no pumping. I am stumped as to where the problem may lie. I have not found where a bilge pump fuse might be, but I'm assuming there is one but it can't have blown otherwise, presumably I wouldn't be able to activate the pump from the switch panel.
I'd be very grateful if you could reveal what secret lies behind the mystery.
Thankyou in anticipation, Bevan Hill
