Stevan47
- Nov 25, 2013
- C-24 C
- Non-Fluid Motion Model
- Recently sold R21-EC
Anyone out there: Yesterday, while back home in the driveway, on the trailer, I was washing out the engine bay/bilge area with my fresh water garden hose. The battery isolator was in the 'OFF' position. I normally either remove the hull drain plug, or leave it in. In this case, I left it in, expecting the automatic bilge pump to cut in once the water level rose, as it usually does, noting the bilge pump is connected directly to the battery bank. The hose was lying in the bilge, full bore, pointing aft towards the bilge pump.
The pump did cut in and ran for about a minute and then cut out. The water level by this time was just near the top of the bilge pump, although I understand it is a submersible device and therefore should not be a problem. The high water alarm had not activated, although the level was still not high enough for this to occur.
I checked the battery isolator was still in the 'OFF' position. I then checked the bilge pump high water alarm and found it to be functioning when I tested it: all good there. The only related fuse at the main fuse panel is for the bilge pump/high water alarm. The bilge pump being connected directly to the batteries has its own fuse link, a 15Amp blade-type (located near the stbd battery, in a brown cable, and contained in a rubber protective sheath) and I found this fuse to be blown. I replaced this fuse and attempted to activate the bilge pump from the main control panel in the wheelhouse: nothing happened. Not sure what to do next and I can only think that somehow, coincidentally, water has got into one of three electrical locations: the bilge pump itself, the float controller located in the bilge, or possibly the float controller switch, which is located at the top of the bilge cavity, adjacent the shaft. I am also wondering if a blocked suction/inlet at the base of the bilge pump would cause it to overheat and/or blow a fuse.
I have not removed the bilge pump, the float controller or the float control switch as yet. Before I enlist the services of a marine electrics expert, can any of you Tug Nuts out there offer me some practical advice/suggestions? I really would appreciate your input and am happy to be criticised constructively.
Kind regards, Stevan
