Bilge Pump replacement 2014 21EC
cdfdoug
I'm wondering if anyone has actually replaced the bilge pump on this model or similar? Mine has quit and it looks like you have to remove (or move) the prop shaft in order to get the old one out and the new one in. Anyone have any experience with this?
I believe Saltwater Joy, Neff is the expert on bilge pump replacement on the R/21.
I have a 2013 R21, Replaced mine 5 years ago, if I remember correctly there are clips that hold it in and can be slid up then around the drive shaft, was a 10 minute job, I do recall needing to trim down a tab on the side of the pump to get the new one to fit in the narrow opening.
Had a 2015, and I was able to get the pump out past everything. I replaced it with the same pump type, so I left the old base in place for the new one. My was a Johnson, I believe.
Thanks so much for the reply's. I ordered the same replacement pump as the one in the boat. I will give it a go when it gets here.
I did have to make a splice on ours...
