Matty
- Feb 20, 2018
- C-28
- IN THE FALL (2018)
While i will do more checking thought i would ask to see if others have had this issue. Both bilge pumps in the aft compartment keep blowing fuses immediately when you manually turn them on. They also do not run automatically now. The switches at the helm trip as well. I reset them, replace fuses and manually turn them on. Switch trips and fuse is blown again. Seems odd it happened to both at the same time.
