I found a couple of numbers -
a 2 inch hole, one foot below the waterline, will flood at 4,680 gallons per hour
a 2 inch hole, three feet below the waterline, will flood at 8,160 gallons per hour.
And don't forget that bilge pumps are rated with no head - i.e. when pumping the water level. Tests show that the little bilge pumps we tend to use run at 50-70% of their rated capacity when they have to lift the water up a few feet. For example, a 1000 gph pump may only pump 500 gph when installed in a boat. It all depends on the installation, and the pump. There are some test results, by brand, posted on the web.
I think a second bilge pump is a great idea, and I think an alarm is even better. I bought one of the Rule Bilge alarm for $60 from West Marine with an 85 db alarm, and in my opinion it is worthless. I doubt you can hear the alarm when the engine is running unless you hold it next to your ear. I'd recommend the Waterwitch....
Mac
