terry.etapa
- Feb 22, 2024
- R-31 S
My 2024 R31 black water tank was pumped out at Elliott Bay Marina, but the tank gage still shows full. Is the sensor an internal float or is it external?
From what we have heard is you can add washing machine soap and water softener to the tank. Then fill up the tank over 1/2 with water. Go cruise around for a while and allow. It the mix in the tank. Then pump out and rinse a couple times too.I have had the same issue and assumed I would need to replace the sensors. If it is cause by a scum line, how do I remove that? I don't think filling the tank with fresh water will do that??
