pugtug613
- Mar 12, 2014
- C-28
- Pugs Tug
I am in the process of winterizing my R27. I do not like using too much of that pink stuff. I drain the tank and the hot water heater and then I blow out the lines with compressed air. That way, I can add 1 gallon to the tank and run 1 gallon thru the hot water heater. I disconnected the hot side on the water heater and blew out the both sinks.(faucets on hot) I wanted to do the same on the cold water. I disconnected the supply side at the pump and blew air into the hose. Not much came out of either hose.(faucets on cold) It seemed different then the hot water side. I even went to the supply side of the check valve (made no difference). Am I missing something? I really do not want to run pink stuff thru those hoses, it takes too long to get that smell out in the spring. Does anyone else blow out their lines?
Chester
Chester
