watson1987
- Jun 7, 2021
- R-31 S
- FMLT3119L718
- Clifford
I'm looking to wire my hot water tank to my inverter, so I have the option when on the hook for 2-3 days.
I need to ensure that both shore power and inverter cannot power the hot water tank at the same time. Having two breakers, with sources from both those sources and the load sides going to the water tank but does not provide the safety of both sources at once. I'd prefer to have the extra switch, so I have to purposely switch it on, and not have to forget to turn it off when I switch to the inverter during day-to-day operations.
I have an R31 with a Blue Sea 360 series panel. Some panels offer lockouts, but I can't find just those breakers sold separately for the 360 panel. My other option is to use an automatic transfer switch behind the panel to ensure both AC sources can't make it to the panel simultaneously.
https://www.bluesea.com/products/catego ... out_Slides
https://xantrex.com/products/accessorie ... fer-relay/
Has everyone else who has wired this up, just put it just wired to the inverter side, and skipped the pass-through AC source from the main shore panel?
