Subject: Bottom/hull paint affects on WOT speed ?
Ever since comparing my WOT speed of my 1yr old 2018 R27/OB that had bottom paint with another 4 month old 2018 R27/OB without bottom paint running at WOT speed I've wondered just how much performance is degraded due to bottom paint.
The comparison was (in salt water on a calm day with no wind and zero chop)
Boat #1 - My 1yr old R27/OB WOT speed with its bottom paint was at around 38.4 mph. (Yamaha 300HP outboard)
Boat #2 - The 4 month old R27/OB WOT speed without bottom paint was at around 41 mph. (Suzuki 300HP outboard)
The #2 boat was some 1/2 mile ahead of me when making this comparison and was slowly getting further and further ahead of me. I (boat #1) had no chance of keeping up with it, and no chance for over taking it. 😉
The #2 boat had two adults on board and at least 3/4 full fuel tank.
The #1 boat had one adult and a full tank of fuel.
I assume both boats had equal amount of gear stowed on board.
My boat #1 had a full cockpit enclosure and a kayak on cabin roof.
Boat #2 had no cockpit enclosure nor a kayak on top.
Ignoring the affect of the cockpit enclosure and the kayak on my boat #1 there's a difference of 2.6 mph for the identical boats except for the bottom paint on my #1 boat.
Could the bottom paint on my #1 boat explain why my WOT speed was 2.6 mph slower ? This is 6.34% slower.
If I use my boat for say 100 hours each year suffering from the 6.34% loss in speed due to the bottom paint I'm using more fuel to get to my destinations compared to boat #2 without bottom paint.
Let's work this out... at WOT speeds.
Boat #2 cruising for 100 hrs travels 4100 miles.
Boat #1 cruising for 107 hrs travels 4100 miles.
According to manufacturer's engine performance specifications both engines will burn some 26.5 GPH at WOT. Thus boat #1 would consume 7 x 26.5 = 185.5 more gallons of fuel compared to boat #2. At $4/gallon this amounts to $742.
I will assume bottom paint for the R27/OB is some $2,500 done every 3 years.
Thus for boat #1 cruising at WOT for same number of miles (4100 miles) each year as boat #2 then $742 more dollars per year is spent for boat #1, or over 3 years this will be $2,226.
It seems from this that from a fuel burn expense the bottom paint is really costing a lot of money; Over 3 yrs boat #1 has to spend $2,226 more on fuel and some $2,500 for bottom paint (a total of some $4,726 more).
I know this probably is not very precise and assumptions have been made, but I'm thinking bottom paint maybe a waste of money and simply having the boat #1's hull power washed once or twice a year is a better solution.
Comments most welcomed. Thanks... 🙂
