Pete: I have no advice or experience with Copper coat bottom paint. However, I do want to add to this thread the fact that having the boat kept in a covered slip will reduce and help avoid barnacle buildup on the hull. Barnacles like sunlight and so if the boat is kept in a covered slip that does a good job of protecting the hull from direct light the likelihood of barnacles being attracted to the hull's surface is reduced.
I keep my boat in a covered slip and have it stern in, leaving just a small portion of the port bow hull exposed to sunlight. This portion of the hull is the only place that barnacles attach to.
I have diver service for underwater zinc inspection and the diver always checks the hull bottom paint by lightly scrubbing it to see how soft it is. My marina has a policy of not allowing divers to scrub and clean complete hulls while the boat is in its slip.
My boat is kept at Port of Edmonds, WA (Puget Sound) in a covered slip and the boat points essentially north in its slip.
My R-25 was originally bottom painted by the factory in 2009. Unfortunately, the method used at that time was to chemically etch the hull before applying a bottom paint. This method was a dismal failure as Ranger admitted to. They no longer use this method. I had my boat hauled out and bottom painted last March. A thorough sanding prep job was performed and two coats of paint applied afterwards. I did not use Copper coat paint per the advice of my boat yard professional who did the work for me. It was very much needed as the original paint was literally peeling off. A light power wash removed the remaining paint with ease. 😉 No matter, even with this initial inferior bottom painting method I was able to avoid repainting the hull for close to 3 years having the boat kept in a covered slip.
My diver tells me the bottom paint remains hard and does not rub off, no barnacles seen anywhere and the boat has been 9 months in salt water since the new bottom paint was applied.
I'm hoping to get 3 to 5 years on my new bottom paint... 😱 :roll:
