When you say power at the switch presumably you mean the switch in the wheel house? If yes then per knotflying's advice check the main power circuit(fuse) to the thruster. If no problem found there then you may have a bad solenoid in the thruster housing or a bad ground. Since the thruster isn't running in either direction the bad ground sounds like the most likely culprit.FIMAN1":2qb1jy47 said:Need help. I have power to my bow thruster switch, but bow thruster won’t run. Any suggestions.
New batteries
FIMAN1":vc6lpybu said:Need help. I have power to my bow thruster switch, but bow thruster won’t run. Any suggestions.
New batteries
Fiman
