buzzing noise from shower sump pump
Captain Mike
C-248 C
2016 R 25 Buzzing noise coming from the area of the hot water tank. General discussion via the forum helped me to isolate the noise. By pulling the shower sump pump fuse I was able to stop the noise.
Now what? what does this pump do, we have never used the shower. I assume this pump remove water from the floor drain in the bathroom.
Where is this pump located, the sound seemed to come from behind the hot water tank. I can see no wires or access from under the bathroom sink so how does one get to this pump to find out what is going on?
Thanks in advance
Not sure on the R25; but on my C28 the sonar transducer is located next to the shower sump.
When the sonar is set for 50 hertz, a clear and sometimes annoying buzz can be heard coming from that area. When set at 200 hertz the transducer cannot be heard.
Probably the float switch on the shower sump. they fail periodically causing the pump to run continuously. Several other posts are active on the topic with potential solutions.
