Aengus
- Oct 1, 2025
- C-248 C
- FML24802G223
- Aengus
I have a 2023 C 248 with the Webasto heater. The heater locked itself out and I need to cut power to reset the controller. I found that the heater is directly wired to the battery with no breaker, only a fuse. I have not yet located the fuse but I was told that it is behind the panel where the battery switches are. I am looking to install a switch to be able to shut off the power to the heater. Has anyone had this issue or installed a breaker/switch? Thanks, Aengus
