Bob/Bradenton
- Sep 17, 2019
- C-24 C
- FRB02830G001
- Non-Fluid Motion Model
- Ranger 21 "Martini" Launch
- Buttercup
Had our 2019 C-28 hauled last week and to my surprise, all the zincs which were installed this past June were gone. The large prop center zinc, the pancake that I installed on the lower edge of the rudder, two zincs that I had installed on the center 1" SS tubing for the swim platform and the two pancakes that I had installed on the trim tabs were just about gone. Mid-Gulf Florida salt water.
H, we have a problem.
All the copper bottom paint, (June, '21) was gone from the prop and some on the rudder and trim tabs. Not a good thing. So it looks like my dock is leaky just a bit. I've ordered from Zincs.Com a reference anode that is used with a multimeter to test for leakage and have just received a new ProMariner Galvanic Isolator which should help with the dissolving zincs til I can figure out the leakage.
Has any C-28 owner installed a Galvanic Isolator and where? I can't locate any of the shore wires that run from behind the shore power inlet but I removed the AC electrical panel and there is a three wire bundle (white jacket with the normal heavier black/white/green wires). This bundle has a hand written tag: "Shore Panel". I am assuming that this is the main inlet cable from the shore inlet.
The instructions for the Galvanic Isolator state to install the unit as close to the shore power inlet as possible, interrupting the green/ground wire with the unit. But since I can't locate the cables, it looks like a good place to mount it would be under the AC panel in the cave and cut the green/ground behind the panel and run it through the bottom of the panel box to the isolator and back. Any comments/thoughts on this?
Thanks, Bob/Bradenton
PS: The reason for the haul-out was to replace the bow thruster leg and both trim tab actuators. I suspect the kids of the former owner "played" with the switches a bit too much. Easy to replace both. Also painted the faded dark blue propane box on the swim platform, white. Also moved those barnacle attracting blue LED underwater lights, up under the swim platform for mostly the same effect, but out of the water so no more barnacles. And one more, I cut out the bottom of the rear seat tray where the two 6" ports were located. The trim tab/engine hatch pump is deep down there to the left and to refill the pump tank, this makes a large opening so both hands can get down there. Used a cheap empty ketchup/mustard squeeze bottle with its long nozzle to refill the pump tank, very tiny filler hole.
