Bob/Bradenton
- Sep 17, 2019
- C-24 C
- FRB02830G001
- Non-Fluid Motion Model
- Ranger 21 "Martini" Launch
- Buttercup
A couple mod's that I've done to this some what, brand new boat: (2019 C-28)
-Moved the underwater blue LED lights to under the swim platform. Same effect but now no barnacles.
-Cut the entire fiberglass area out from under the rear seat. So instead of two very small ports, now I have full access to the very important gear that is under that seat. Especially the Trim Tab/Engine Hatch hydraulic pump, which there is no way to properly access/re-fill it with those small ports. Now, full access. Use a cheap "Ketchup" plastic bottle to refill the ATF fluid in the pump. No spills.
-Replaced both Trim Tab actuators. About $100/each. Blew out the bottom of one, no idea why. Had the boat hauled to do that but it could have been done in the water. The top of the Actuator where it goes through the hull is not under water. And there is enough slack in the inside line that it can be pulled out of the transom for the new Actuator.
-Replaced the auto-sensing rear bilge pump with a separate flapper type pump. Made a mount for both.
-Added a digital voltmeter (cheap on Amazon) to constantly read the House Battery voltage. One back by the inside sink pump switch (taps into that power source) and one at the helm. Easy and can be constantly monitored.
-Added a Galvanic Isolator. Cheap and easy to install in the Thruster/Engine Start Battery compartment. Somewhere there is a huge leak, either on the boat or my dock and within three weeks all of the new zincs were gone. Now with the Isolator, they are fine. (But I do keep the boat unplugged from shore power now).
-Added a fan to each side facing the pilot and mate seat. This is Florida, need the air flow. Easy to install.
-Added mounts on the helm for an iPad and iPhone. The iPad is used as a GPS backup and the iPhone mainly for Pandora linking to the Fusion radio.
-Added the same type of fan in the Head.
-Restitched the entire Bimini top. All of the threads (wrong thread used from the factory?) gave out and it was falling apart. Almost new boat.
-Larger spade type Ronca anchor. That tiny Bruce style would not grab the hard sand here. Now works great.
-Changed out the stock AGM batteries. The House side would not hold a charge so I replaced all four with InterState G-31's, Deep Cycle for the two House and Starting for the Thruster and Engine Start.
-To change the charger parameters, you have to access the charger, which is installed way back next to the hot water heater. Very dumb place for the factory to put it. Extended the wires and moved it next to the Auto-Pilot pump. Easy to change now. Plain sight.
-Moved the Solar Panel/Rack forward. Another very stupid factory design. If the sun is from the rear, the radar dome blocks the solar panel. Plus the four hatches won't open all the way, almost not at all. Extended the cables and moved the rack forward. Easy to do. Now no shading and all the hatches can open all the way.
-Replaced the bow thruster prop/leg. Under warranty but I had to haul the boat to do the work. Easy to do. Access to the inside bow thruster motor is good, but you are hanging upside down. Buy the special ratchet wrench if your boat didn't come with one.
-I remove the 15 amp helm fuse to fully turn off the fridge. I will add a heavy duty switch at that fuse panel to do the same.
-Removed that stupid Wine-Cooler. It doesn't really cool since it is a Peltier effect chip. It draws 4 amps when it is ON and it will be ON most of the time. Very inefficient. Now, lots of storage space.
-When I first got the boat I had added traditional St. Croix swing davits to the swim platform. I have photos if anyone wants to do this. But took them back off since it added another five feet to the boat when the Dyer Dhow was swinging on them and I'm in a condo "small boat" dock.
-Painted that dark blue (faded/2 years) swim platform storage box top "white". Looks a lot better and no waxing.
-Added zincs to the Trim Tabs. Salt water use.
-Added a pancake zinc to the rudder, lower edge.
Just thought that I'd outline some of the mod's that I've done to my new boat. Bob/Bradenton
