Bob/Bradenton
- Sep 17, 2019
- C-24 C
- FRB02830G001
- Non-Fluid Motion Model
- Ranger 21 "Martini" Launch
- Buttercup
Low hours, about 20 in our 2019 C-28. Went to start it today, cranks and cranks but no firing.
Thought that it might be the first fuel filter, the metal one that on our boat, that might be clogged.
(The metal can is rusted on so the filter can't be inspected, but I did drain it and the fuel was clean).
So I disconnected it from the line and joined the incoming 1st filter fuel line to the incoming of the clear Racor. Drained that one and refilled.
Just cranks with no firing. Never happened before. Always started.
The only "fix" that I did was a couple weeks ago I adjusted the fuel shut-off selenoid, per NextGen instructions since the gen would not turn OFF. That fixed it, just one turn on the bolt. But ran fine after that. Start and Stop.
I'm going to replace both of those small Racors with a Racor 500. Per NextGen, the original metal can first small Racor has a 10 micron filter to pick up the big stuff and the last one with the clear plastic housing has the 2 micron. Per NextGen, you have to use 2 micron as the final filter so that's the one that I'll use in the single larger Racor.
But before I go back to Ken at Racor, (again), any ideas why it's not firing? Fuel and Air makes these things work but there seems to be quite a number of small gizmos on that gen. Again, a very low hours gen.
Thanks for any ideas/comments...Bob/Bradenton
