C-302 radar error code 1007
Paige_A
R-25 (Outboard)
Majestic Sunset
We have a Garmin 7612 on our (2018) C302 and our radar is showing "Radar Error Code 1007 High Heater Voltage". We cannot find much information online. Has anyone experienced the same and what was the issue? Thanks.
Error code 1007 means that the heater circuit voltage is too high. Normally this is because the heater is not working,either from a loose connection or a failed heater board. You will need to check all power connections and the connecting cable connections for corrosion or damage. If that doesn't fix problem than you will probably have to send unit to a repair facility. Good luck Bob
