The dreaded shower sump pump issue. New to me C26, and I just got around to testing the shower sump before a trip planned for the weekend. Ran some water to fill the sump, yet the pump never turns on. Disconnected and removed the float switch wiring and tried directly wiring the pump to the live 12v feed from the fuse panel, and nothing. So before I cut myself up removing this sump setup, I was contemplating ditching the sump box altogether and just using an inline pump to evacuate the shower as needed. Seems a few have done this with success. I just want some opinions before I simply replace the pump, and have to be back mucking with this setup every few months. Is anyone's fairly trouble free? If not, perhaps inline and ditching the box is the way to go. I'd just have to figure out the plumbing reducer/adapter, as the drain intake is much larger than the discharge.
Any other thoughts or suggestions before I purchase parts?
Cheers,
Severum
Cheers,
Severum
