JonR
- Jul 19, 2020
- R-21 EC
- Good Time Tour
First: to those who have responded to my posts - thank you! I've had many questions with no answers since purchasing my boat used last Nov and finally decided to hit this forum for answers. I have appreciated the responses I've received. They've been very helpful.
Today I learned something while at my boat. I ran into an owner of a newer 30 ft cutwater and he happened to be replacing his aft bilge pump. I asked if I could see the installation as I need to replace mine. I had thought that I had to unscrew my aft pump to replace it. At least in his case, you could remove the pump w/o removing any screws. Is this the case with the pumps on the C28 (2014 Volvo Penta).
I also was concerned about what I thought was a float that was not attached to anything and laying right down in the pump area. After some discussion with the other owner, we realized that it was my high water alarm! Obviously, this is concerning as I have had no alarms going off and it shouldn't be floating in the water (under the shaft) right next to the pump. I looked all over for a place where it might have been mounted originally and see nothing. First, I would like to know where the proper installation is, and secondly, any thoughts as to why the alarm is not sounding? Do this go out now and then?
