JonR
- Jul 19, 2020
- R-21 EC
- Good Time Tour
Several weeks after having the starter replaced in my 2014 C28 Cutwater, I suddenly experienced a significant oil leak, even when the engine was not running. Unfortunately, this resulted in a fairly significant oil spill within the marina causing them to have to place booms around roughly the 5 surrounding slips. Coast Guard got involved as well. NOT GOOD!
When I finally got permission to leave the marina for repairs, I had the engine removed. The theory was that the oil pan had corroded to the point where is had begun to leak. Of course, one of the major jobs was to clean out the bilge which was full of oil. When cleaning, a small socket was found - really didn't think much of it at 1st - assumed that the 1st owner had dropped a socket. However, when the oil pan was pulled, it became obvious that it had not corroded but a large crack in the port side was found in the same area as the forward motor mount (under the starter). Looking closer, there was 'rub marks' that could be seen in the hull in the same area as the cracked oil pan and you could see where the pan had been rubbed until the pan was worn to the point where it cracked. Most likely, the 12 mm socket got lodged between the hull and the pan and ultimately resulted in the damage described above.
I'm not sure how the socket got there (I had a qualified technician replace the starter) but the result was devastating. I'm sharing this as a warning to others - no FOD in your bilge! The distance between the engine and hull is minimal.
For those wondering if I pursued this with the technician, I did not. He replaced the starter as a 'side job' and there is no way to prove that it was his socket. It could have been there before he changed the starter? I just chalked it up to 'another hard lesson learned'.
And, while the engine was out, I had the opportunity to do some things:
Replaced all the raw water and closed loop water hoses
Replaced the serpentine belt
Replaced the water pump impeller
Replaced the engine zincs
Replaced the 2 rear motor mounts (expensive buggers)
Replaced the forward Bilge pump
Put in a PYI dripless shaft seal
Had my prop balanced
Added a thru hull sending unit
New bottom paint
Added Bennett down tabs (thanks to the forum) to my trim tabs
Had the transmission rebuilt
Replaced the nonfunctional outlet in the Bilge - the original install was stupid - installed right in line with the 'shift drip' and when shaft is turning at cruise (if you're dripping a little too much) salt spray gets slung right towards the outlet. The original box cover had to be open to plug in the engine heater so there was no protection.
Fortunately, my Nephew owns a large boat repair shop so we pulled the engine at no cost on a weekend and I'm not having to pay for 'dry dock' time. Still, it is an expensive lesson to learn. Hopefully she'll be back in the water in the coming week.
New bottom paint
