JonR
- Jul 19, 2020
- R-21 EC
- Good Time Tour
I own a 2014 C28 Cutwater. I have recently replaced my inverter. More about this later... In any event, I replaced it with a TruePower Plus 2000 pure sine wave (ps) inverter. It's great. I can finally make coffee on 'battery power' - popcorn??? - have yet to try the microwave.
Anyway, to the point: The remote for the inverter is different that the one that is originally mounted on the power panel at the entrance to the 'cave'. It appears that I need to get behind the circuit breakers in order to route to wire for the remote to the inverter located in the battery compartment. What's the easiest way to get behind the panel? Has anyone had any experience here?
I ask the last question because I can see why others may have problems. Early on, when I first owned my used boat, I met a man at Friday harbor who had just replaced his due to 'salt water' intrusion. We were talking inverters because I had questions as to why mine didn't seem to work correctly. It later became clear why salt water was an issue. If your shaft seal is dripping a little too much, it slings salt water in a plane in-line with the dripping shaft. Unfortunately, this happens to be right in-line with an opening between the engine and battery compartment for the bilge pump hoses, etc. Salt water gets slung right onto the outlet & plug of the inverter, mounted on the back wall of the battery compartment, that feeds the cabin wiring/outlets. An, if you have an outlet within the engine compartment, it is also right in that same plane, which, with the original design, had an 'outdoor cover' that had to be open in order to plug in the engine heater. Not a great design.... When replacing mine (for the 2nd time) I realized that the previous owner(s) had also replaced his inverter twice in the 4 years prior to me owning it. Just passing this on for others awareness
Things I've recently done to resolve the issues:
- Replaced the GFCI outlet and cover using a newer now accepted outdoor cover that can be closed when heater is plugged in
- Replaced my old seal with a dripless seal
- Because there was not enough wiring length to replace the plug and still reach the inverter, I put a junction box in the lowest hatch below the ice chest which allowed to to add wire length, replace the plug, and provide a proper wire drip loop for the plug. It was an easier path that replacing the full length.
- Replaced my aft bilge pump which checks every couple of minutes to ensure bilge is always empty.
But finally, I can have my cup of coffee 🙂 Any knowledge/experience with rewiring the inverter remove would be appreciated.
Jon
Jon
