C28 packing gland wrench size
jswhal
Cutwater 28
Sea Glass
What size wrench is needed for the gland and lock nut? I can't quite tell if it's 2 1/4 or 2 1/2.
This is the wrench you need to break the lock nut free. You might need to attach a breaker bar to the handle of it if the lock nut is corroded tight. This wrench opens to 2-5/8":
https://www.amazon.com/RIDGID-31305-Wre ... B0009W9BT0
Also, you need to get this plumbing slip wrench to place on the adjusting packing nut to hold it in place while you break the lock nut free:
https://www.amazon.com/Adjustable-Wrenc ... lip+wrench
After the lock nut is free, use the slip wrench to make very, very small adjustments to the packing nut to get the right drip rate.
